It is currently Fri Aug 22, 2025 4:37 am
 Post subject: Sapwood and aesthetics
PostPosted: Sat Aug 17, 2013 8:41 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Zip/Postal Code: 30501
I would like to hear opinions and see pictures of guitars that have sapwood with and without backstrips. Also, if your sides are wide enough to eliminate the sapwood is it desirable to do so? If you must use sapwood on the sides, should it join with the top or back? Any important things to know about when working with it?
Good judgement comes from experience. Experience comes from poor judgement.
PostPosted: Sat Aug 17, 2013 12:23 pm
Last Name: Howard
City: Magnolia
State: Delaware
Zip/Postal Code: 19962
Not all sapwood can be used. It depends on the species, some have sapwood that is non functional as wood while others the difference is more cosmetic.
Brian
PostPosted: Sat Aug 17, 2013 12:41 pm
PostPosted: Sat Aug 17, 2013 1:14 pm
As mentioned, not all species have suitable sapwood.
But where included. I personally prefer not to use a back strip.
On the sides, I prefer to keep it, if proportional and pleasing, and to position it towards the soundboard.
PostPosted: Sat Aug 17, 2013 2:24 pm
First name: Bryan
Last Name: Bear
City: St. Louis
State: Mo
Filippo's first post has all the points I was about to make about back strips. As for the sides, it can look nice. I would orient it on the soundboard side since that is the straighter profile and you will plane/sand away less sapwood when you taper the box. Your binding purfling scheme may need to be adjusted depending on the colors you are using. . .
Bryan Bear PMoMC
PostPosted: Sat Aug 17, 2013 2:27 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Which woods have unsuitable sapwood? Come to think of it, I believe the only guitars with sapwood that I have seen were either Cocobolo or Ziricote.
PostPosted: Sat Aug 17, 2013 2:40 pm
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
This is the set that I had in mind when I made the original post. The grain is straight enough that I was considering a strip. The Greenridge in pic #1 makes a compelling argument for no strip with straight grain, though.Image
PostPosted: Sat Aug 17, 2013 2:58 pm
First name: Peter
Last Name: Fenske
City: Leeds
State: Yorkshire
Country: Uk
Personally, I think a backstrip wouldn't look good on that back. It looks great as it is.
And I think sapwood on the sides can look stunning.
Pablo Picasso
PostPosted: Sat Aug 17, 2013 3:02 pm
Last Name: Arnold
City: Newport
Zip/Postal Code: 37821
IMHO, it is not a question of species. The viability of sapwood is mainly determined by how the wood was processed. Sapwood is much more vulnerable to decay, fungus staining, and worm holes. If the wood is processed right away, the chance of degrade in the sapwood is much less. Once the wood is dry, degrade stops.
The key is timing.....bearing in mind that the degrade happens a lot quicker in the tropics.
I have always used a backstrip when sapwood is present in the center of the back, but I just play around with the sides to see which edge looks best. In many cases, the Brazilian RW sides I have used are only large enough to be used one way.
Brazilian RW:
Interestingly, most people who see sapwood in the raw sets don't like it, but when I show them a finished guitar, they change their mind:
Amazon RW
Honduran RW:
PostPosted: Sat Aug 17, 2013 3:45 pm
Last Name: Kincheloe
Gorgeous set wow7-eyes Use it just like it is.
I tend to like backstrips on guitars without sapwood, since the back can be kind of boring otherwise. And with curly woods, I hate the look of the runout inversion at the centerline, but interrupting it with a strip makes it look more symmetrical again.
Sapwood is kind of like a natural backstrip... I see no reason to add any more, unless there are symmetry issues needing to be distracted from.
I consider it a tragic waste to cut the sapwood off trees before slicing them up. You can always make the sets extra wide, and then chop off the sapwood when joining if you don't like it. Madagascar rosewood is especially sad, because the trees are too narrow for QS backs, and a lot more sets would have the "eye" outside the waist if they kept the extra inch or two of sapwood in the middle. You can always add a center wedge of maple or something for a similar effect, but it doesn't look as nice as the natural edges of the heart to sap transition.
PostPosted: Sat Aug 17, 2013 3:54 pm
I love sapwood. I think it can look really cool!
Depending on the set, I usually orient the sapwood on the sides towards the back, it can be quite decorative.
Old growth, shmold growth!
PostPosted: Sat Aug 17, 2013 4:23 pm
I'm in the no-backstrip camp...
Mountain Song Guitars www.mountainsongguitars.com
PostPosted: Sat Aug 17, 2013 5:21 pm
State: PA
PostPosted: Sun Aug 18, 2013 1:32 am
First name: Tim
Last Name: Mullin
City: Shefford
State: QC
Zip/Postal Code: J2M 1R5
I think sapwood works perfectly by itself as a very organic back strip. My personal preference is to find sets which also feature sufficient sapwood on the sides so that it is visible along the entire side.
This Malaysian ebony is my favourite example to date:
PostPosted: Sun Aug 18, 2013 7:36 am
First name: Casey
Last Name: Cochran
City: Gainesville
State: GA
Wow, now THAT'S a nice gift!
PostPosted: Sun Aug 18, 2013 1:20 pm
Last Name: Howard
City: Magnolia
State: Delaware
If actual strength was the only concern than most sap wood would be suitable for use as long as it was aesthetically acceptable. We deal with wood in extremely small cross section and it behaves somewhat differently at this scale. sapwood is very open in cellular structure. It was designed and used to transport sugar water (sap) throughout the tree. The heartwood has been "modified from this form to provide a structural element with no other real biological function. Wood does not forget this, it remembers it was a tree, always. As such, sapwood can be more susceptible to movement caused by RH swings. This effect can be magnified by our thin cross sections. Heavier, denser woods seem to have less differences here. As do woods with generally high resin content. I also agree with John about processing. The sapwood in air dried stock always seems a bit punkier.
Brian
PostPosted: Sun Aug 18, 2013 4:40 pm
First name: Jonas
Last Name: Baker
City: North Haven
State: CT
Zip/Postal Code: 06473
So I have some rosewood pieces big enough for fretboards and bridges. So you could make a fretboard with half sapwood and half heartwood, for instance. What do folks think of using sapwood on Fretboards and bridges?? I think it could be used in an interesting way, but I'm not sure if people would think it would look strange.
Jonas
PostPosted: Sun Aug 18, 2013 5:38 pm
First name: Tony
Last Name: C
City: Brooklyn
Sapwood on a fretboard? Yup. It can look great.
http://www.CostaGuitars.com
PMoMC
PostPosted: Sun Aug 18, 2013 11:07 pm
First name: Ringo
Indeed... I try to keep it on the side that won't get dirty though...
PostPosted: Mon Aug 19, 2013 4:35 pm
I have a sapwood fetish.
Here are 4 of mine.
PostPosted: Mon Aug 19, 2013 5:58 pm
First name: nick
Last Name: dingle
Bubinga....
Blackwood....
Ziricote....
I prefer the sapwood without a backstrip. In fact, if the bookmatch is good, I prefer no backstrip at all...
PostPosted: Tue Aug 20, 2013 12:15 pm
Tony and Fili, well played on the fretboards!
I generally like sapwood on the back if it is not parallel to the seam and has an ending. (such as Nicki's) Or if it is, as long as it's not wider than a quarter inch per side.
PostPosted: Tue Aug 20, 2013 12:25 pm
theguitarwhisperer wrote:
Sapwood heaven from the sapwoodwhisperer.
Well that JPG didn't transfer, but I was referring to his/her cocobolo guitar.
PostPosted: Tue Aug 20, 2013 3:49 pm
First name: Philip
Last Name: Marcus
City: Cedar Creek
Zip/Postal Code: 78612
Holy kaleidoscope, Batman! Youse guys are reeeeeaaaal good! Take it from me, otherwise known as "wierdo artist guy" - More asymmetry, please.
